1975 rude 9.9 lube questions
tanuki
Was wondering what substitute for ?Lubriplate 777? to use for the electric starter pinion shaft on a 1975 Rude 9.9? Hate to buy a can of this stuff as the quantity in the can is too much for my needs. Also the motor has a grease fitting to pump some grease into the bracket where the motor swivels from side to side on the bottom, but I was wondering how to get some grease into the top as I see no fitting there?
boobie
Re: 1975 rude 9.9 lube questions
OMC used to use the 777 but now they recommend Versi-Lube. It's expensive so you may want to stop by a local dlr and buy a small amount of it for your mtr. The swivel bracket on your mtr only has one fitting to lube it.
tanuki
@boobie...thank you for that info.
boobie
You're welcome. Hope you find it.
