1975 model 135 no spark
Dewayne45
got a problem with the right side of the engine not firing. have tested the stator and pick up coils and they all are fine. got a new power pack and still not getting any fire on right side. Can anyone help? also installed 4 new coils and they test good. ????:confused:
Joe Reeves
Re: 1975 model 135 no spark
There are two (2) sensors in/on the timer base. One fires the port bank, the other fires the startboard bank. You have either a faulty sensor OR a break/short in one of the senors wires on that bank. Disconnect the sensor wires from the powrpack for that bank, then check it with an ohm meter.
Dewayne45
we checked that lastnight and all tested good but still no spark. is there anything else that we might be over looking?
Dewayne45
Problem solved finally!!!! Had to readjust the gap of the sensors on the timing plate. Thanks for all your help.
