oba97
Thread starter- Joined
- Jul 28, 2015
- 277
During winterizing the motor I came a cross a few issues (first time ever winterizing a outboard). I have done some research and think I have found some answers but would like to get some feedback on my path forward. Having never done this before any input would be great.
1. When I was fogging the carbs they died right away. I expected that they would sputter a little then die......is this normal to die so quickly?
2. I noticed water coming out from about all 4 of my spark plugs. From what I have read it is probably a leak in the water jacket gasket? I did change my water pump impeller at the beginning of the season. I have read that a new impeller can cause more pressure eventually causing a leak? Assuming I am right I plan on changing the gasket over winter.
3. I noticed some dark black oily material leaking out from the hub area of my impeller. I think this is caused by incomplete combustion during fogging?
4. I definitely had water in my lower unit oil as it was milky when I drained it. I changed the oil mid season and there were no issues at that time. I did not use a new o rings when reinstalling the drain and vent screws. I am going to refill, install new o rings and recheck the oil after my first outing next spring just in case the water intrusion was from reusing the old o rings.
Any input or advice would be greatly appreciated.
