1975 merc 1150 wont start
glenster
ok so i put the boat in the water and it won't start. it turns over but doesn't even try to start. i smell gas so i think its flooded. so i start the 7.5 and go fishing. 2 hours later i try to start the big motor and still nothing. so i pump the bulb to make sure its hard. go back and try to turn over but only get some clicking. now i took cover off and the starter looks like is stuck engaged. i assuming that it works like a car. i can see it is engaged with the flywheel. its not suppose to be like that right? thanks glenn
frabcabert
Re: 1975 merc 1150 wont start
I had the same problem, turned out to be my battery. Oh the wierd things a bad battery can cause. My starter would get stuck engaged, wouldnt stop spinning, engine would just crank. Got a new one, charged it and Bang, all the problems gone. But dont take my word for it, I'm no pro at this, just my experience.
glenster
thanks for the reply. its a new interstate marine battery but i did crank it alot trying to get it started. so i will charge it up and see if it will crank over.
