1975 Johnson w/ throtle problem
rallo54
I have a 1975 115 Johnson outboard motor with a throttle problem. The choke cable broke, then I tried adjusting the throttle while on the water and the engine raced. I shut it down right away, but when I tried it again, it wouldn't do anything. I tried trouble shooting that problem; I think the starter solenoid is not functioning. When I turn the ignition switch I don't get any voltage through the solenoid or on position 7 or 2. I couldn't find the automatice shut off switch if there is one. Is there a concrete test to do for the starter solenoid? Or what else could it be?<br /><br />The throttle will not go in reverse now. I took off the control cables to the engine, and I opened up the throttle casing. It looks like the lever is all the way to the right in the neutral position where I think that is the position for reverse. Is there anyway to adjust the lever, or do I need a whole new throttle assembly?<br /><br />If so, does anyone know where I can get a throttle and a starter solenoid inexpensive?<br /><br />Thank you
OBJ
Re: 1975 Johnson w/ throtle problem
Hi Rules....<br /><br />Listen partner....before ya' tear anything else apart, please get a service manual. From your post I'm not real sure what to tell you. <br /><br />Won't start after high rev episode.....since you got the contol box open, look for a push button switch in the box. If this switch is not made up, the engine won't start. This is because the control box is still in a "gear" position.<br /><br />What is the choke cable you referred to? Not real sure about that one.<br /><br />But you do need a manual or take it to a mech and explain what's going on to him.<br /><br />Generic type manuals can be had from iboats store or search for Ken Cook Co. for a reprint of the original OEM manual.
