1975 Johnson 50hp have a Telltale hole?
jklug1
Does a 1975 johnson 50hp have a telltale hole? If not, is there anywhere water should come out besides where the prop mounts? (exhaust)
Thanks in advance if anyone can answer this.
Bosunsmate
Re: 1975 Johnson 50hp have a Telltale hole?
Im not sure about the peehole but it should come out just under the lower front mount.
If you are on muffs make sure they have good pressure, but not too strong.
If in a container check the water is at least four inches above the top of the gear box.
vendingworks
my 0976 70 hp does not have a peehole,only2 small holes on back of engine. Couple of years was like that.
