A crankshaft seal caused it to stall? I dont know much about motors, but that sounds odd. I only inspected one plug when i pulled it, even though i took out both. I think i realized something was not right when i did the low speed jet adjustment. Is there a second screw that sits on top of the needle? there is a brass one with a sort of cup on the bottom, and if you look down in there, there is a second screw head it looks like. The brass one, that is visible on the exterior of the carb is not in the diagrams. Thats why i assumed it was the needle, but when i look it over again, i dont think i adjusted the needle, but rather a sort of set screw on top of it.
In the pic, you can see the screw heads of the brass pieces. When you remove them, the other end does not resemble the needle in the manual at all.
