Bombard Brent
Thread starter- Joined
- Feb 27, 2009
- 21
I recently purchased this very clean motor that had sat for >10 years. It started without much effort, but there was no water coming from the blubber hole and the head became very hot to the touch quickly. So...
-I replaced the water pump even though everything looked great.
-I pulled the water cover and found that there was a small amount of blockage around the thermostat. I cleaned and cleared the blockage and replaced the thermostat. The rest of the water jacket from what I could see was pristine.
-With the water cover off, I hooked the hose up to the water tube and turned the hose on. At first, nothing, and then a release of pressure and water (with some crystals) from near where the thermostat sits.
After I reassembled the motor, I ran it on muffs and in a tank. There were dropplets coming out of the blubber hole (almost scalding hot) and the head still felt very hot, although not as hot as it was prior to replacing the thermostat (I could hold a finger to parts for around 10 seconds).
Perplexed,
-I took the lower unit off again and examined the pump. It looked good. I hooked a hose up to the water tube, but I don't get any return (presumably because the thermostat is closed).
-I pulled the head to see if I could visualize any obvious blockage. It was pristine.
-Finally, I opened the water cover and removed the thermostat.
-I started the moter and the result was that there was a spray from the blubber hole and the head did not feel hot to the touch.
-Lastly, I put my new thermostat in a pot of hot water. It started opening around 150 degrees.
My confusion comes in part due to having a 1974 Evinrude 9.9 that has never let me down. It sprays a nice mist out of the blubber hole and the head is always cool to the touch. Am I being overly concerned by the seemingly hot operating temp of this motor? The water pump is good, the circulation appears good, the thermostat works, but jeeze it seems HOT! I am going to put the thermostat back in tomorrow and use a infrared temperature gun to see how hot it is getting unless someone can point out something obvious for me to consider.
Sorry for the long post, but I'm running out of ideas.
Perplexed,
