buddyholly
Thread starter- Joined
- Jun 11, 2004
- 77
Have a '75 115, it starts fine but when lowering to normal idle it slows down til it finally dies. choking when it is doing this doesn't keep it from stopping, but when choking it, rpms. will jump sharply for an instant then will kill. I have replaced needles and seats, new bulb and installed a clear inline filter before the bulb because there is no filter in the tank on the bottom of the dip tube. when running the filter does not fill up with gas, but at Wot the motor runs really well, but at lower speeds it kind of surges and lowering even further it will fade out and die. Have also taken the pump apart every thing looks good. The only thing that I haven't replaced is the pump and the fuel lines under the hood. If I replace the fuel pump do they still make a kit for it and if not will another pump fit. the numbers on the back of the pump are 318374. Help I am ata loss here.
