1975 johnson 115 does not fire.
chanelcat
i just bouhgt a boat it has a 115 johnson on it,the guy i bought it from siad it ran last year and had the power pack replaced on it,after getting it home i charged up the battery and tried to start it.no luck, it cranks ok,but does not fire at all, i checked for spark off one of the wires and didnt see any,any help or opinions would be apprecated, thanks
Dhadley
Re: 1975 johnson 115 does not fire.
If you are sure spark is the problem, disconnect the main harness plug (red) and check for spark. Use a starter button to engage solenoid. Check for spark on all 4 cylinders with a spark checker. Check with the plugs in and out. Let me know what you find. dhadley50@aol.com. Once you get spark, have the carbs cleaned BEFORE you start it.<br />Good luck.
