scanman
Thread starter- Joined
- Jul 29, 2010
- 370
Re: 1975 evinrude 9.9 fuel pump prob?
ok, it's not bound up.
Bk, the timing marks I'm confused about are the ones on the timing plate. Iput white out on the flywheel marks & they show up well. The points only have about 1hr on em but I checked em again today anyway. They wouldn't wear that quick, would they?
jmendoza, thanks for all the info. I cleaned the points like you said(COOL TRICK). Timing checks out with an inductive light. I've tried many new sets of plugs. The needle, after days of adjusting seems best at 1 1/4 turns out. Yes I used a new head gasket & properly lapped the head. Visual check today shows nice clean seals all over. I installed a new stainless steel thermostat during rebuild & it is working properly when the engine is up to temp.
Today I started it up, got it warm. Did a compression test. both cylinders are @ 75psi. cleaned & gapped the points, new plugs. This vid was made at 6pm central time today. It shows that playing with the choke was no help & just how bad it idles.
http://www.youtube.com/watch?v=3w67MtjMkPo
Tomorrow I'm gonna get new soft plugs & re-do the carb, cause I'm outta ideas. I almost hope I did screw it up. I'll keep checkin in tonight.
I can't thank yall enough! I know we'll eventually get this thing right.
