Good day all during a search I found this site and I have to say I like it. Anyway I tried searching and couldn't find my issue maybe someone can help, I have a 75 9.9 I changed the impeller and all the stuff in a kit, went to test and noticed at high rpm water is coming out the exhaust relief hole for lack of a better term not telltale and water is coming out from under the lower cowl and from under the front of the motor by the carb. No water is in the cowl by the motor that I can see. My question is is this an overflow from the new impeller or are some seals or something bad. When I got home I noticed what appear to be weep holes on the underside of the lower cowl which is where the water was coming out. Sorry for the long post and thanks in advance
