jbwathen23
Thread starter- Joined
- Apr 11, 2015
- 9
Hoping someone could help me cause im about to loose my mind!! im pretty mechanically inclined and i thought i could fix anything until this problem... its a 1975 evinrude 85 hp.. it idles like complete crap.. sneezes idles up and down half the time cuts off after it sneezes... sounds like the bottom carb is where the sneeze is coming from.. ive replaced fuel pump new plugs rebuilt the carbs ( about ten times ) using carb cleaner and air.. i have my timer base air gapped at .005 ( i played around with that moving in .001 increments it runs better at .005) ive changed flywheels thinking i could of been a loose magnet.. replaced all the fuel lines and also by passed the tank and line going to the tank buy hooking it directly into the pump.. any ideas would be much appreciated.. i dont have a dva so i havent checks the power from the stator or coils.. boat ran fine last year sat maybe 3 months... starting to think it could be something with the reeds maybe???
