1975 Evinrude 70HP, Model: 70573 (E) -- Battery Question (CCA)
JTOutboards
Hi everyone!
I'm new to the forum and was wondering if I could get some help trying to start my 70573e Evinrude outboard . I'm definitely not an expert and welcome any advice you're able to provide!
Background:
I have a 1974 Chrysler Boats SPORT FURY connected with my 70573e Evinrude and haven't attempted to run it in over a year (it started and ran properly a year and a half ago). I've been considering selling the boat + motor and wanted to make sure that it is able to run in order to demonstrate that it works for any potential buyers. Naturally, the battery was dead and now I'm wondering what type of battery I can use to start the boat with (without having to go out and buy a new deep cycle marine battery).
I checked an old Evinrude motor manual rated for 50-140HP motors and it stated that a CCA of 360 or 500(V6) would be good enough. I attempted to use the battery from my truck that I measured 12.35V with 625CCA. The terminal rings didn't fit on the battery terminals so I had my friend cautiously hold them down to get a good connection (https://imgur.com/a/2CCIg). When I turned the ignition I saw the choke go up and down but the starter didn't engage. I even tried hooking up the battery with jumper cables to another nearby vehicle for extra power. I still got the same result. Lastly, I guess it wouldn't hurt to get some fresh gasoline going through the system. The gas I was using when I tried to start the boat was kept well in a sealed container but was also pretty old. I'll only be using this as a demonstration to get the motor running. Running the motor with an improperly rated battery and poor connections is definitely not the way to go.
My Question:
What CCA is required to start a 70573e Evinrude outboard motor? Can a truck battery be used to start this motor? What else could be going on?
Thanks for taking the time to read all that. I guess at worst I'll be out $100+ for a new battery and it might still have other issues. At best I'm just being dumb and didn't hook something up right.
F_R
Honorary Supreme Mariner
If it starts your truck, it should start the outboard. I would suspect the hookup. I'm wondering why the clamps didn't fit. They should, tapered style battery posts are all a standard size. Be careful, a poor battery connection can blow the alternator rectifier.
F_R
When I said it should start it, that's what I meant. It should start it. That doesn't mean it is adequate for continued regular use (or not).
JTOutboards
Thanks for the help, F_R.
I updated my post with some more info and added a picture of what type of setup my battery looked like. I mistakenly said battery clamps but meant its like a metal ring that cannot be adjusted. And also I have to agree with you that this is definitely not the way to run a motor intended for regular use. haha :)
