I recently bought a 14 foot Savage with a Evinrude 50573b 50hp 1975. It sounded good and started first kick with the muffs and hose. Took it out and didn't get much speed about 20kmh tops (Sorry I'm an Aussie) about 12mph. Anyway in neutral I pulled up the throttle lever to show my bro it had plenty of rpm and I said maybe it's the prop slipping? or the pitch? too low? Regardless when we took off it stalled and would NOT start. Only backfiring every 20 seconds. We embarrassingly got towed in by some nice blokes and gave them a few beers as thanks. When I got back I tried to start it , still just backfiring loudly ever 20 seconds of cranking. Checked the grounds, all seemed good. Changed the sparkplugs to new NGKs (Nothing) Checked coils, bottom ones High Tention lead just fell out of it when i wiggled it and even though I was getting spark when i put them back in I decided to buy new coils, not expensive and couldn't hurt even if it was something else. Replaced coils still just intermittent loud back fire , just every 20 seconds or so, like it was fluking timing? I dunno, I'm very new to this caper. Went through the trouble shoot in the manual with a multi meter a best as I could but it asks me to use a neon light meter to check the power pack. I figure it could be the Power pack maybe? I'm hoping it's not the Charge coil or sensor coil because I believe I'd have to replace timer base or stator as well if that's the case. I don't have a neon S-80 or M-80 light tester as they suggest in the manual? I hear they haven't been used for years! Can anyone suggest how I test the power pack without a light tester? Just a multimeter? I'm going to do the trigger coil input check tomorrow with a spark tester I made and a 1.5volt battery hooked up to 6 and 7 on the power pack and then reverse it the sensor coil high ohm check which says it should be 750-75ohms . In the meantime, can anyone suggest the reason this just happened out of the blue? I'm a novice and one of you guys might know exactly what it means , Going then stall and not even kicking over. It could even be a fuel or carby thing? I dunno? , I checked the compression and it was up at around 145psi on both , which I thought was extremely good for such an old engine. So that's obviously not the problem. All help muchly appreciated!. Cheers, Ash
