redssteelers
Thread starter- Joined
- Jun 29, 2012
- 3
Good day everyone, Bought a pontoon boat with a 1975 evinrude 40 hp 40555c. The motor doesn't like to idle at low rpms. I changed coils, both were cracked. Then I changed fuel lines, bulb and put on a new tank. Also replaced water pump. Nothing has helped. Put new plugs in - same thing. Checking on the evinrude site the plug that I replaced j8c is not the correct plug. UL81C is the correct plug. Would changing the plug help with the idleing issue. Thanks for any help. Once the boat gets to about 1200 rpm and above it purrs like a kitten. Will push the pontoon boat along at 19 mph. James
