1975 Evinrude 25hp, need cylinder head, what years work?
brockj
Hi all!
I have a 1975 Evinrude 25hp, after a little work she was running good, until the upper spark plug hole got cross threaded, so I need to replace the cylinder head now. I was talking to someone and got a cylinder head from a 1972 Johnson 25hp, that was supposed to work, and though it looks like everything lines up properly, there is no where to mount the coils! So I am wondering what years/hp's would be a compatible replacement for this motor?
Thanks in advance!!
Kflc
Re: 1975 Evinrude 25hp, need cylinder head, what years work?
hi there, you should be able to get a threadsert/ helicoil installed, especially if it takes 1/2 inch plugs. You will then not need a new head. You also do not need to remove the head to have it done as the motor will spit out the swarf when it starts.
brockj
Thanks for the reply. I actually did have that done, (well I did it myself), and it did not stay. It worked fine for a few outings, but my last time I used it, it blew the spark plug and insert right out of the head! Thankfully I had an electric trolling motor to get back to shore, but have not used it since.
