vidsdinerie
Thread starter- Joined
- May 11, 2013
- 19
1975 Evinrude 25 HP - rope start
Having trouble finding cause of bottom cylinder dropping out under idle or low load - when I throttle up both fire fine and engine runs smoothly at nearly full throttle this is what have I done so far:
1. Found emulsified oil in top cylinder (spark plug threads and inside cylinder when head pulled) and it would leak emulsified water from weep holes for days and days - resurfaced head and replaced head gasket - Cold compression in both cylinders was 120 psi before and after head gasket changed. Thought this was cause of misfire - it was not. Engine no longer weeping emulsified oil and no emulsified oil found on plug anymore.
2. Removed plugs and checked for sparks while hand cranking - found one cylinder not sparking (do not recall which one)
3. Removed flywheel and check points (points and condenser were replaced last year with Factory parts - <10 hours on them now. Both points in good shape (look new) - checked gap and ok but reset to 0.020 inch per manual on set mark. Magnets on flywheel seem to have good and equal strength.
4. Checked plug for spark and replaced what I though was a bad coil with new - took boat to lake and same problem - misfire unless loaded above slow no wake speed power - Ughhhh!!!
5. Put motor in tank and started engine till problem starts - occurs fairly quickly - removed one coil wire at a time while idling and engine would not on on bottom cylinder - swapped coils so new coil on bottom and repeated test - same problem - will run on top cylinder when lower wire pulled will quickly stall if top cylinder wire is removed.
6. Rechecked point gap and they are still both 0.020 in
Any ideas?
John in Erie.
Any ideas?
John in Erie.
