1975 evinrude 15hp sticking in reverse
superfluke82
when motor is off and is in neutral, propeller does not spin freely very well and i can hear a click noise when it's spinning. If motor is in forward or reverse the propeller will not spin in any direction but does have about 1" of movement.
When motor is on or off If i put boat into reverse and go to neutral it'll click but it wont go out of reverse. I have to put motor in forward than go back to neutral so it'll actually go into neutral.
Suggestions? lower unit need servicing?
flyingscott
Is this motor new to you? Something is out of adjustment. Look at the detent on the side of the motor and make sure they line up there might be an adjustment there. If the lower shift rod has been turned you need to check that. Drop the lower unit and turn the lower shift rod until tight then back it off only enough to line up with the upper shift rod. Or somebody took the pivot bolt out of the lower unit and that is the problem.
superfluke82
No Title
I played with it and detent needs adjustment but it needs to be fixed first. Guy who originally had motor had built a Frankenstein motor he patched a bunch of stuff together. The threads that hold detent on is completely stripped in the block. He jammed it full of locktite that didnt work. do you think if i wrap bolt in teflon tape it'll work? any other suggestions? i'll attach pics
superfluke82
I think i will have to. i dont think rethread will work i can pretty much push bolt all the way in dont think much left to a good bite with out trying to find a new bolt. teflon tape failed
