1975 evinrude 115hp starter solonoid
Malina26
The starter solenoid has power on the main lug from the battery, as soon as the solenoid engages you hear the click but then I lose my 12volts on the main lug. Any ideas about where to start?
Honorary Supreme Mariner
Check all battery cables and connections.-----Load test your battery even if new.----And if starter is original it would be a good idea to pull it apart to inspect brushes.---Little bit of grease for bushings.----Easy job.
Malina26
I did all the above and if I take a jumper cable and go straight to the starter it will work. . But if I go thru the solenoid I have 12 volts on the main lug until the solenoid energizes.
McGR
Check your voltage across the battery terminals while activating the start circuit. If it checks OK, then you have a voltage drop somewhere between the battery and solenoid - probably a poor connection somewhere.
Well----I think that 12 volt circuits are very easy to trouble shoot and repair.-----The trouble might be that as simple as poor connections or bad ground.----Keep us posted on the outcome / solution-Thanks.
F_R
Symptoms strongly suggest a bad battery cable connection. Don't just look at them and wiggle them, remove them and clean them shiny clean and reassemble tightly.
