crestlinermusky
Thread starter- Joined
- May 9, 2010
- 110
Took out the boat today for the first time after rebuilding
the floor & transom. Boat and motor performed flawlessly.
Got a lot of help from everyone here.
Question for today is, on Friday evening, ran the motor
on the muffs, had to remove the housing and manually
choke the motor to start it. fired right away.
Took it to the lake this morning, had to manually choke the motor to start it. It will not start using the fast idle lever on the control box if the motor is cold for a few days.
Once I get the motor running the idle lever works fine, it is just at start up, does this mean the automatic choke does not work or it needs an adjustment.
