1975 Chris Craft Lancer
jbur2002
I have a 1975 Chris Craft Lancer with an orignal 350ci Chevy. Is this a counter roating motor? Any help would be greatful.
Don S
Re: 1975 Chris Craft Lancer
NORMALLY, they are standard LH rotation with a single engine. That does not mean your 75 engine hasn't been changed.
Does it crank over? If it does, just look at it and see which way it's turning.
ziggy
generally i don't think they put counter rotating engines in single engine boats. sometimes in twin engines setups. sometimes the engines rotate the normal direction and the change of direction takes place in the drive.
i think the normal direction is cw when viewed from the fore side of the engine.. looking at the balancer. looking aft in ft. of the engine.... if i'm wrong, i'm sure someone will set you and me straight...
Ayuh,... What's the Driveline,..?? Who's I/O,..??
Chances are it's a plain ole lefthanded standard motor....
