1975? 90HP Chrysler impeller
gmoir_2
Hi,
I have a 90HP Chrysler with the model number 907HA. I believe this is 1975. After running it in a barrel of water the temp. sensor activated and it was shut off. I took apart the drive leg to inspect the impeller which is badly worn.
I am in Scotland and no-one I have been to can tell me what impeller I need or another one that would fit.
Can anyone tell me a part number/manufacturer that could be used to replace the impeller I have. If anyone has links to anywhere that sells them it would be appreciated. If not, I will search the net for the part number/manufacturer.
Thanks
Glen
gmoir_2
Re: 1975? 90HP Chrysler impeller
Thanks a lot Gerry.
I have managed to source an impeller on ebay.
Thanks again.
Nordin
You can try FranzMarine.com. He will help you.
