1975 9.9HP and 1976 15Hp Lower Unit Interchange
OptsyEagle
I own both of the motors above and have decided to take the powerhead from the '76 15Hp and put it on the mid-section of the '75 9.9Hp since my 15HP has some useless motor mounts. The head bobs around quite a lot and the 9.9Hp seems to be fine. I don't want to pay the very high price to replace the motor mounts and I happen to have this parts motor that I could possibly use to replace them.
I also thought I would use the lower unit of the 9.9Hp motor since the 15Hp has a little more corrosion on it. It works fine but the 9.9Hp looks a little better. When I looked at the parts diagrams for both motors I noticed that the gearcase casings and the mid-section housings are identical part numbers, but the drive shafts have different part numbers. I also noticed that the two respective motors have different part numbers for their pinion gears.
I guess my question is, does anyone know if I would be able to take the lower unit of a 1975 9.9Hp motor and shove it up into the powerhead of a 1976 15Hp motor. I am thinking that maybe the reason OMC uses a different part number for the drive shafts is for a change in the end that goes into the pinion gears and if I am using the entire gearcase, this may not matter, in my situation.
Has anyone done this or encountered this issue or have any thoughts at all?
kbait
Lower units will swap if both motors are long shafts, or if both motors are short shafts. Driveshaft to powerhead coupler splines are the same.
OptsyEagle
That's what I thought. I will look closely at them both but I have had both lower units off the motors at different times and I did not notice any difference then.
I thought I would ask because everytime I shove a lower unit back up into a midsection/powerhead it always seems, for a while, that it is just not going to fit and then with a small move of the flywheel or propeller, up she goes.
Thanks for the reply.
