1975 85hp johnson won't go into gear
Jay hartley
I sent the boat to our local marine to have the carbs fixed because before it wouldn't start now it starts no problem but I cannot get it to go into gear. I've tried moving the lower unit and I can get it to go into gear by hand but how do I adjust the rod and know that it's in the right spot? Just trial and error or what? Only thing I've seen online is 2 or more rotation from the bottom of the rod but I have to remove the whole lower unit to adjust the rod. Any help would be great
Jay hartley
Yes it goes into gear by hand but I can't get the cable to make the unit go into gear. And the local marine isn't somewhere I'd want to take the boat again way too expensive for what they did and didn't fully fix the boat
oldboat1
It sounds like the remote cable needs to be adjusted. Detach it and shift at the motor, like you are doing. Line up the cable end with the opening, rotating the adjustment knob. Reattach and test remote shift.
When the motor isn't operating, you may have to rotate the prop with your foot to get the gears to mesh.
Rustywrench
One other thing to add to what oldboat & racerone are saying. This shift mechanism has a lot of lost motion in it of any of the bushings are lost (your fine dealer) or broken. Look at a break down of the parts. You have a small bushing at each end the bellcrank & larger bushings in the middle of the bellcrank. You can over come this lost motion by hand shifting, but cable actuation can't be made to compensate for all of it. Just an idea to check. All of this didn't need to be undone to do carbs, but some dealers will work in that area.
F_R
Sounds like somebody's being unfair to the marina. "Took it to the marina to have the carbs fixed" Who's diagnosis was that? Now it won't shift. No reason to mess with the shifting to fix carbs. Well, I will have to say the tech should have tested the completed job.
Jay hartley
I agree F_R they didn't even take it off the trailer. But anyways I Removed the lower unit today and adjusted the shift rod down and now I can feel it shifting into gear with the cable connected (not in the water but testing in the back yard) but the prop only locks one direction while in gear. Everything I've read online says Johnson motors shouldn't spin both direction. But the other direction with enough force will turn flywheel and the other way just clicks with not much force. so is this normal?
F_R
MANY motors just click in one direction. I can't sit here and remember/list which ones do or don't. So I would assume it is normal on yours.
