First off,
I appreciate all feedback even if you don't know the answer and just have some ideas of what to try!
1975 Johnson 85hp - New to me boat.
Here is the issue: My controls box is skipping a gear inside the box. Inside the controls box there are two gears that each have 2 teeth, One plastic that is directly attached to the shift cable to the motor and one metal attached to the shift handle. When I shift from neutral to reverse everything is fine. When I go from neutral to forward (just enough to engage forward gear, no throttle) it works fine. When I go past just engaging forward to full throttle then back to neutral the plastic gear catches on the detent on the metal piece on the shift handle and causes it to skip a tooth. I then have to tear the control box down to reset the gears for it to shift into reverse again.
- One little trick I found, If I disconnect the shift cable from the motor (very little force on the cable to operate) the controls work great. Once I hook up the cable to the motor which causes a little more force to operate, the gear will catch on the detent at full throttle.
- This is a new boat and the issue came about because when I bought the boat, the plastic gear was broken and wouldn't shift at all.
- I have checked all the shift linkage from the box back to the engine and all is good.
Has anyone had this issue or have any ideas on why this is happening?
Thanks
Thanks
