1960 Starflite
- Jun 23, 2011
- 408
I?m back with a throttle linkage problem on my 1975 850. For a little history on this engine, the boat/engine belonged to my Uncle and he took it to a marina a couple years ago because it was idling too fast. They got it to idle at a lower speed, but still high.
I bought the rig for the engine to mount on my pontoon. Now that I have the wiring replaced, carbs rebuilt and the water pump rebuilt, I am nearing the time to mount it. While placing the throttle linkage on the engine (control clamped in vice), I find that I can?t get the linkage to push the distributor against the idle screw. The picture of the engine linkage is as it came back from the marina. So I thought ?I?ll adjust the inner cable? like on my old 1963 650, WRONG, looks like the inner cable is held in place by some kind of swedge/clamp, no set screw like the old style. So I pulled the control apart thinking I can adjust the barrel on the threaded anchor, WRONG again, the barrel is also somehow permanently mounted to the outer cable. Both of the barrels (throttle and shift) are one inch from the outer cable housing. Both cables are the same length and have the same travel.
I am now at a loss on this; can someone guide me in the solution to this problem? Sorry for the long post, but wanted to include as much information as I could.
Thanks, Tom on Buckeye Lake
