1975 6 HP Evintude - Lower Unit Gear Oil
jwday
Does anyone know the capacity of lower unit gear oil for a 1975 6 HP Evinrude outboard?
My service manual fails to indicate how much oil it takes.
Thanks
tx1961whaler
Re: 1975 6 HP Evintude - Lower Unit Gear Oil
The answer is : "until it squirts out of the top vent hole."
I honestly don't know the answer. I have a gallon container with a pump on it and fill it until it comes out the top hole. My manual doesn't list the capacity either...
jwday
ok, thanks.
I was pumping from a quart bottle of lube very slowly and it finally came out the vent hole. It doesn't seem like very much oil. But then again, the gearcase isn't very big either.
Thanks
5150abf
I normally buy 2 bottles, then fill the one you are going to use clear to the top, makes it alittle easier to get it clear full.
Put it in till it comes out the top hole and it is full, just that simple.
Vic.S
An 84 model 6hp takes 325 ml.
Its a different design of gearcase but the two cannot be vastly different in their capacities.
A genuine English quart is a bit more that 1100ml IIRC but I think an American one is a bit smaller so i'd expect it to take something in the region of 1/3 of a US quart.
Don't forget all the mechanical gubbins takes up a fair bit of space inside the box
jwday
This makes sense because I think it took approximately 300 ml.
Thanks for that confirmation!
Rick.
Interesting, because that is what I figure my 9.9 takes, very close to 300ml. Rick.
coolguy147
hey same here
