1975 50hp Johnson wont run
Russbigs01
I have a 1975 50hp Johnson that was running fine when parked last fall. Now there is no spark, any ideas on what to start with? I put a spark tester on the plug wires and there is no spark. Any idea on where to go next? Thank you.
Daviet
Re: 1975 50hp Johnson wont run
Go to CDI's website and look up your engine and use their troubleshooting guide to check out your system.
hidef
Follow the steps on page 33 of the troubleshooting guide. The link is in my sig. Good luck.
Russbigs01
Thank u for the link, I think it will help me alot. I will let u know later today. Thanks again
skipper711
You may be able to help me, is there any chance you could put a couple of pics of your engine on the thread, as I have a Johnson which I believe to be a "1975 50hp Johnson".
It has a transom bracket off a 79 55hp Evinrude so I really do not know the exact Johnson year or hp.
Thanks.
skipper711
Russbigs01, I have just put a photo of my 50hp on the thread I started "Advice", I would appreciate it if you could tell me if it is the same as yours. skipper711
Russbigs01
It looks the same as mine, the only difference is mine is white.
I did a few things off the link that one of the previous posters posted. Nothing seemed to be working, one night after work I went and turned the key and it started right away and has been working great since!
hotshot123
if you have no spark at all, im going to guess that your trigger is bad. I would use the CDI site and check that trigger really good.
BonairII
If it was running fine last year....make sure to clean up all connections to make sure that it isn't something as simple as corroded terminals.
