1975 50 Sizzler Misses
rancher161
Need Help ! My 1975 50 Sizzler starts excellent, runs great until about 30 minuites into the ride , then when you try and go to full throttle it sputters and misses. Fine when the motor has been running for under a half hour.<br />Fuel ? or Spark ? <br />Any help would be great help.
Basscat 1
Re: 1975 50 Sizzler Misses
welcome to iboats.<br />Sounds like the coil starts to break down when it gets hot. Figure out which cylinder loses spark when this happens and you will know which coil is going bad.
rancher161
Thanks, That sounds right to me. The coils are inexpensive and easy to change on this motor so I will probably swap out both anyway.<br /><br />Thanks Again
