1975 50 hp johnson outboard won't start
cfirneno
13 plus volts to top of solonoid no click or start, no power to the small terminal top of the two smaller terminals. tried to jump from top battery cable to start voltage goes away no movement of starter. all connecttion seem tight and clean
oldboat1
Didn't quite follow your description of solenoid terminals, but try jumping directly from battery to starter. Object is to see if the battery is functioning correctly, then go from there.
cfirneno
did that nothing happened used jumper cabls from batterty terminal on solonoid to the red wire on starter nothing
oldboat1
no, jump direct from the battery like jumping two car batteries. In fact, use jumper cables -- positive battery post to the stud on the starter. Cable from negative post to the starter bracket. The starter gear should snap into place and spin the flywheel if the starter is good.
