1975 25HP evinrude Wont run at full throttle
Michael77
I have a 1975 25hp Evinrude. It runs really smooth and starts right up but there is one problem, at full throttle after a couple of seconds the engine sounds like its revving really high almost as if its in neutral but its not jumping out of forward gear. I just put in a brand new clutch dog and forward and reverse gear. It runs fine at about 85% throttle but once i go for full throttle it seems to rev high and then i have to back off the throttle. Any suggestions anyone?
14ftgrumman
Re: 1975 25HP evinrude Wont run at full throttle
If the motor rev's and you don't go, look for a spun prop.
Remove the prop, mark a line accross the back of it with a marker, put it back on. Go for a ride and check the lines when you get back. I'd almost bet that they won't line up.
Daviet
I agree, sounds like a spun prop hub to me also.
Michael77
Even though the prop is pretty much brand new? u Think its on wrong? Or is it something else?
Michael77
