Re: 1975 135 evinrude
Also, test with all of the spark plugs removed. Be sure that you have a solid ground on your test device(s), and that your battery is fully charged and can turn the engine at 300 RPM.
The 1973-1976 135HP motors need special attention to grounds on the ignition system so it is a good idea to clean all of the connections when experiencing ignition problems. The rack on which the powerpack and ignition coils are mounted had problems with grounding as well, so clean the grounding straps running from the rack to the cylinder heads.
If the ignition coils are cracked, discolored, swollen or melted, they should be replaced.
