Hey guys, so ive had a number of threads going here with a number of problems but ultimately i found with a compression test that i have one bad cylinder with about 40 PSI after decarbing the engine a bit, so i pulled off the head yesterday to "hope" that i had a blown head gasket and ultimately found the following located in the pictures in the below link
https://onedrive.live.com/?id=8046A5...4zKWSk&o=OneUp
http://1drv.ms/1JC8Aey
it looks to me like a ring broke, caught on the exhaust port, and blew a chunk of the top of the piston off, heh you can actually see the peice of the ring sticking out, I really don't know when this happened, it could have happened as late as last year, the boat seems to run pretty good otherwise, being down a cylinder an all, there really doesn't seem to be any damage to the cylinder wall in the bad one, there are two very small nicks by the exhaust point but otherwise the walls are perfect,
i guess i have two questions
1. there are two nicks by the exhaust ports on the cylinder wall, looking for some opinions, would you just ignore this damage shown in the picture and put in a new piston and a couple new rings and hope for the best? this engine is 40 years old and i don't really want to put a lot of money into it, which is all about what owning a boat is about i know, and i know i "should look at taking it all apart and getting it all machined and new everything, but hey like i said, i dont really want to do that
2. Can i replace the single piston without totally dismantling the crossflow v4 engine? i don't really see where the crankshaft is, must be behind the intake plate behind the carbs, but has anyone taken one of these engines apart? would i be able to take the connecting rod bolts off and slide the blown piston out all by itself and replace her without total dismantling the engine? not best practice i know, but hey, its 40 years old
thanks guys in advance, appreciate the advice and thoughts as always
