Hey everyone I have a 1974 Johnson 15 hp model 15R74S. I bought this and used it a few times but it sat for awhile when I was away at college with the occasional friend usage. When I returned I noticed it wasn't put away properly so I recently pulled it apart. I replaced a pull cord and the spark plugs. When I pulled the carburetor apart I noticed the float was the original cork so ordered a kit and replaced it. Unfortunately I broke the throttle shaft when trying to beat out a roll pin to remove plastic linkage to dip clean the darn thing. Replaced the throttle shaft and put everything together. I adjusted it so that in start position the roller matches the hash mark on the timing plate. When I fire it up it fired in full bore open and no matter what I do i can not get the rpm to lower. I have tried messing with the idle needle and the idle speed on the port side of the engine. Anyone have any ideas out there?
