1974 mercury 1150 - no spark
jdonald
Motor was running perfect last season. This year we installed a new battery that spins the motor fast -would not fire - no spark. I need a trouble shooting chart with electrical values to trace the problem. ( ohms across coil primary is almost 0 ohms) Can anyone steer me in the right direction? (my kids want to go skiing and summer is passing) Thanks, Jim
Moody Blue
Re: 1974 mercury 1150 - no spark
First thing to check is voltages at the switchbox.
Non-distributor side of switchbox.
Key OFF.
+12V at red terminal
0V at all other terminals
Key ON
+12V at white terminal
Check these out and post back with results.
Coils rarely go bad.
Post a S/N of the motor to confirm the year.
jdonald
serial #- 3761333
voltages check out as described
I jumpered white/ brown wires on dist. side of module - grounding black wire did not induce spark on coil wire
Voltage while cranking is 9.6 on red and white wire on side opposite dist.
no voltage on green wire while cranking
rotor turns while cranking (belt not broken)
Thanks, Jim
Moody Blue
serial #- 3761333
Thanks, Jim
Hope you disconnected the distrib wires before jumpering as you described. If not, you probably toasted the trigger circuit in the distrib. Where did you have the coil wire when checking for spark?
Cranking voltage is about right.
Do you have a mercury tilt switch still connected to the switchbox? If so, disconnect it, it may be faulty.
jdonald
Yes, I followed the directions on another post I found on this site and disconnected trigger wires first.
I tried jumping the spark to several different places to make sure I had a good ground. There was no hint of a spark on the black wire I was grounding to induce the spark. I left the "capacitor?" hooked up on the brown wire post for the test.
What and where is the tilt switch?
Thank you again, Jim
Moody Blue
What you referred to as the "capacitor" is the tilt switch.
It is a mercury switch that shuts down the ignition if the motor is tilted too high during operation.
If that switch has gone bad, it may be disabling the ignition system. Disconnect it to be sure its not the problem.
jdonald
When I disconnect the tilt switch - key on - 12V at red and white terminals on non dist. side.
Brown and white jumpered on dist. side - momentary connect of black post to ground - No spark on coil wire.
Is the switch box probably shot?
This switch box is a used one that came off a 4 cyl. merc. about 15 yrs. ago.
There must be some latitude in what model and year motor the switch box comes off of?
Thanks, Jim
Chris1956
It sounds very much like the switchbox is bad. Most 4/6 cylinder 70s merc switchboxes are compatable.
