1974 Larsen shark 1650
canuck169
I am a newbie to this I have been given this boat and I need help with stringers and floor ... I have scraped out all foam and this boat did not have stringers in tri hull anywhere all it had was 1 x 4 on flat I need help please on what to do next
Re: 1974 Larsen shark 1650
Ayuh,.... Welcome Aboard,... Post up some Pictures...
Triangleboater
No stringers...seems fishy. Pictures would help immensely.
This is a 69 Shark, 17'
The only wood was a pair of 1X10's resting on 3 1X3's
They were tied in with heavy Roven and Foam.
jmmacky
Get yourself a photobucket account (Photo and image hosting, free photo galleries, photo editing) which is free. You can then upload your boat photos to your photobucket account. When you're looking at a photo in photobucket if you click on the box that says 'image code' it responds by saying link copied. You can then simply paste that link into this thread and the photo will be displayed when you click reply. It's really easy and you can even download the photobucket app to your smartphone if you have one and see your photos/send them to people/upload from phone camera.
P.S. I don't work for photobucket!
canuck169
Does anyone know what kind of foam my shark will need under the floor for buoyancy ????
canuck169
I also need to know what size wood and what kind I should use for my floor ...
JASinIL2006
Yup, the 2 lb. density is probably what you want to use.
canuck169
This is the inside of my 1974 Larson shark 1650 special edition .... From my feed back I am going to run 2 1x4 on the flat down each side of the middle held up by 3 Pieces of 2x4 and 2- 2x4 's on the flat across front n back of boat ... Should I try and put 1x4 on flat on each side as well as I need to fasten deck down somehow ..... After wood is in I will glass them in with braid fibreglass
canuck169
Anyone know a wax or type of restore that will bring the faded blue back it's only been in fresh water if that makes any difference
Woodonglass
If I'm not mistaken that's what's known as a Foamed Hull. No Stringers and gets it's structural integrity from the foam filling the entire hull cavity. You will need to do your homework on how to build your deck and then how to pour your foam to ensure that it Properly fills and supports the hull as it did from the factory. It's critical for that hull design since it does not have stingers for support. You might want to PM Ondarvr, one of our members. He might have some Professional insight on this one. I might be Off Base on this, but I don't think so.
canuck169
Anyone know how many gallon gas tank ( approx) was originally in this boat and the location of it
Ayuh,.... If it's Outboard powered, probably a 6 gallon portable stuffed under the splashwell...
akayer19
Was there any luck restoring this boat?
I just acquired a 1975 Larson Shark 1650...
I have the same setup so I am quite interested...
Thanks Alex
