1974 johnson 70hp stator?
Bob427
203.jpgi just noticed recently that i have some brown sticky stuff dripping from the bottom of my stator coils
does this mean its getting hot or is just the insulation breaking down
the motor runs great other wise
and the stator checks out ok with my ohm meter
thanks Bob
Bob427
Re: 1974 johnson 70hp stator?
bump
Bob427
ok finally got a pic of it
Bob427
Bob427
could this be caused from a bad regulator?
miichael18
its normal my 1974 evinrude was leaking so i bought a new one 4 years ago and it leaked too shortly after. if it aint broke dont fix it.
Joe Reeves
That pictured stator with the exposed coils is the original stator that the engine is equipped with when sold new. The newer ones are completely shielded with epoxy.
The black coils provide power to the powerpack, needed to energize the ignition. When those coils melt down, it results in a voltage drop which will in turn result in weak, erratic, and eventually no ignition.
Replace the stator!
Note: It's possible that a shorted rectifier has failed which would cause voltage to back up at the stator. This would result in having the stator overheat. Check the rectifier as shown below.
(Small Rectifier Description & Location)
(J. Reeves)
On most 2,3,4,6 cylinder engines, the small rectifier is located on the starboard (right) side of the engine just in front of the engines electrical wiring strip. There are a few older V4 engines that have the wiring strip on the rear portion of the engine and the rectifier would be located just under that terminal strip. The smaller horsepower engines usually have the rectifier located on the starboard side of the powerhead close to the carburetor area.
The rectifier appears to be a round object approximately one inch (1") in diameter and also about one inch (1") high. The base of it is sort of triangular in appearance and is attached to the engine with two (2) screws/bolts..... usually one screw/bolt is larger than the other. The rectifier, depending on which one your engine uses, will have either:
One Red wire, one Yellow wire, and one Yellow/Gray wire, or One Red wire, and two Yellow wires.
Note that either of the above rectifiers could have a fourth wire which would be Yellow/Blue
Bob427
thankyou looks i will buy a new stator and regulator
Bob
