1974 Johnson 70hp carb question
jerrydwin
Does anyone of a picture showing what connects into the fuel tip under the bottom carb? It's on the plate that goes over the carbs and the back covers bolts to it. Thanks in advance!
gm280
:welcome: aboard jerry to iboats.
See if I can understand what you are asking. You want somebody to take a picture of their engine like yours, so you can see how yours goes back together...is that correct? This doesn't help you presently, but any time you start any project, you start by taking tons of pictures from every angle possible for such reason you now need. I don't have a 1974 Johnson 70hp engine but maybe others that do will chime in and offer up a few pictures... JMHO!
jerrydwin
I'm sorry, I should have given more details. I bought a boat that had this motor on it. When I took the cover off I noticed nothing connected to that fuel tip. I was asking what is supposed to be connected there. I can get pictures later when I get off work.
Chinewalker
That fuel nipple is for the return line for the carburetor box/cover. If you look at the carb box base, at the bottom corner, you'll see a similar fuel nub. A hose runs from the carb box to the intake manifold to burn up any spray back from the carbs.
