1974 Johnson 115, telltale?
sr2
is there a tell tale on the 1974 115hp johnson, I sure dont see one.
Honorary Supreme Mariner
No there is not.--Test your overheat warning horn first.------If you do not know how old the impeller is you need a new one !!------Tell tale can be added and I believe there is a spot on the waterjacket of the # 1 cylinder where you can do this.
