SHSU
Lieutenant Junior+Starmada Splash Of The Year 2019
Thread starter- Joined
- Mar 8, 2017
- 1,782
Howdy All,
So I have been lurking on this forum for some time reading all the different rebuilds and such and got the itch. Went out and bought a 16ft Starcraft and will/am doing a complete gut and restore. I AM A GLUTEN FOR PUNISHMENT!!! Also avid DIYer and love to tinker hence why i am doing all this and not just re powering. Will post up in the restore section once i get further along.
So seeking some assistance, I am doing it a little different in the fact that I started with the motor (Evinrude 1974 70 HP 3 cylinder 2 cycle Model 70773s (Powerhead was replaced apparently)) and did a almost complete overhaul (Only thing I didn't do was redo cylinders since compression was good but did clean heads and everything) and replaced all seals and such and got it fired up first try. So moved on to the tilt trim which was working but the assist ram had a blow out so tore both rams apart and will be replacing all the seals on it and will be good (Harbor freight spanner wrench for $5 worked perfectly). I took the motor/pump apart, will be getting a new motor (172850); however, in me zeal to take everything apart and clean everything i also took the pump (172857) apart..... Let just say that I now have 2 sprockets, 2 springs, 2 balls, a washer, and a brass mushroom bushing (Not sure what to call it) that i am not sure how they are to go back together. I can't find any diagrams on the pump assembly. I don't want to spend the money on the motor and then find out that i missed something on the pump when it exploded on me.... Does anyone have any suggestions/diagrams, or should i just pay the extra 80 bucks and get a new hydraulic power unit with reservoir and modify it to work?
Thanks
Thanks
