1974 evinrude help needed
IWANNABOAT
Hello all.<br />this is my first posting on this board. Im glad i found it, looks like alot of info can be found here. Heres my problem<br />I have a 1974 evinrude 50hp on my 16' sea nymph. I have just got done fixing it up (the boat) the motor is in excellent origninal cond. I just went to run it for a while in my test tank. But i took the propeller off so that it wont spit the water out. As i put the boat in gear (forward) an alarm sounded from the control lever. Loud buzzing sound. Any ieas what caused that?? I am thinking because there was no propeller on it. Any ideas would be great. <br /> :p Tom
ob
Re: 1974 evinrude help needed
Welcome aboard IWANNABOAT.Sounds like an overtemp alarm.Has the waterpump and T/stat been replaced recently?How long did it run in the test tank before alarm sounded?Did the test tank have sufficient water level above the waterpump intake?
IWANNABOAT
thx for the quick response, Yes the water level was definetly above the intake ports. I had it at least up to the exhaust ports. Now as far as the water pump i dont know when it was replaced last. I have not seen any water come out though. It is my understanding the water should be coming out of the lower exhaust ports just above the intake ports. Am i correct. If thats true then i am also assuming i have to replace the water pump :( <br />Not looking forward to that but i guess its good we found this out before we got on the water.<br />Thans again<br />Tom
