miichael18
- Mar 24, 2004
- 161
ok guys and gals i need some help. I have a 1974 evinrude 70hp engine that i have owned since 2002. Iv had 1 coil pack go bad and i replaced power pack and stator since i have owned it. its got brand new spark plugs gapped at .030 QL77JC4. all spark plugs have good fire. electric choke does not work so i have to use manual choke. when i get to the lake i pump up the bubble and pull the manual choke which chokes all 3 carbs. i move the warm up lever up and turn it over till it cranks but it takes forever to start. it hits and dies hits and dies. if i dont choke it it just turns over and never cranks. if i squirt some starting fluid in carb it fires right up and idles fine and runs fine untill i shut it off again. i dont know if its flooding itself out or if its not getting enough gas or what. it runs great once it gets running and it idles fine but it just will not start without starting fluid. got new gas in tank also. i have never rebuilt the carbs but i have cleaned them out 2 times and they look good inside so could a carb rebuild (new gaskets and needle) solve my problem maybe? its got good compression on all 3 cylinders it just will not start. now if its hooked to the muffs it fires right up everytime. put it in water it will not start up without starting fluid. may need a link and sync and check timing maybe? iv never done that. any info or advice would be great thank you.
