1974 Evinrude 50hp
chipfish
My motor runs great in dry dock. Put it in the water and it starts to accelerate and drops back to putting along. Put the choke on full and it will run about half speed. I have checked fuel lines, fuel pump, and cleaned the carburetor. What could be the problem?
Honorary Supreme Mariner
Well, it is NOT running great in drydock !-------It just sounds good to the untrained ear.----------My bet is that it is running on one cylinder.---------Start with a compression test.----------And does spark jump a gap of 7/16" on both leads , yes or no ?-----------And did the motor sit for a long time ?--------Did you remove the high speed jet that is screwed into the bottom of the float bowl, yes or no ?
jimmbo
When you cleaned the carbs, after reinstalling, did you do a link and sync?
chipfish
Top cylinder 130 and bottom 150 compression. Cleaned carburetor, bowl, and jets. Checked spark plug gap. Now starter engages but motor won't turn. did not do syn and link, don't know how.
