1974 Evinrude 50 Sizzler compression results and starting problem
DavidHJ
I bought a used pontoon boat that came with an old 74 Evinrude 50 motor. I managed to start it and run for 1-2 minutes after replacing spark plugs and ignition coils. I also replaced the water pump, and did the compression test, top cylinder is ~80, bottom one is 120. I am new to outboard engine and since the compression readings are varied so much, is it worthwhile to continue my path? If I need to open the cylinder head, what should I be looking for? The second question is that after assembling the lower unit back when I replaced the water pump, I can't longer move the gear shift backward (only forward and neutral), does it mean the gear rode was not inserted in proper position in the linkage, should I just remove starter and screw again, and adjust the gear shift before I tight the screw again?
Thank you!
Bosunsmate
id take the head off, look for any sign of pitting on the pistons or scuffs, gouges on the wall. If not it might just be an old head gasket thats leaking a bit f compression.
try turning the flywheel a bit by hand and then try reverse, might just be unmeshed gears
boobie
Pull the cylinder head and have a look before you do anything else.
DavidHJ
Spent a few hours this weekend, figured out gear shift problem. The gear rode was not properly screwed into the shift linkage in the mid part when I replaced water pump and assembly it back, it is pretty hard to see, especially the first time.
Today I was able to dry start the engine for a few seconds, then put into water bucket, it won't start anymore. I did not get a chance to check the Sparks yet, wonder if the carb is flooded, and I did see some oil/gas came out from lower unit around exhaust area in the water bucket. Is this possible? I still need pull the cylinder heads and figure out compression variation. Should I replace some parts, like gasket, thermostat, anything while the heads are opened?
