1974 Chrysler 75hp 757HA Prop questions..
fcross69
Can I run a non splined prop with a shear key on a shaft that has splines and a shear key? If both inner diameters are the same?
steelespike
Re: 1974 Chrysler 75hp 757HA Prop questions..
I know it has been done. It is referred to as a drive pin,Be sure it fits right. You don't want to damage the hole the prop or shaft. And carry some spare pins.
Frank Acampora
Did you not like my answer to your first post? Sure, you can "get away" with doing what you want to do but eventually it may turn around and bite you in the a##.
fcross69
I found a 18 splined prop today with a thrust pin, prop nut, and cotter key for 60 bucks was wondering if I tighten the prop nut until the prop stops on the thrust pin then tighten to cotter key?
