1974 Chrysler 135 hp limping
WinnerCougar74
OK, yesterday the motor was running the best it ever did since I owned it. I had about a 15 minute run back to the dock and about 10 minutes is I heard a small pop and the engine slowed way down. It started up but I could only get it up to about 2000 rpms so we limped back to the dock. Today I pulled the plugs and they looked ok, checked the fuel pump diaphragm and it was ok, pulled the float bowls and caught the fuel in a container and almost identical amount in both, Then ran compression, #1-140, #2-140, #3-90 (ran it 3 times, all the same) #4-140. Hand turned the flywheel while holding a screw driver against each piston and all 4 pistons had zero play in the assembly. #3 seems normal. I have not looked inside the cylinder. My best guess so far is a blown head gasket.
jerryjerry05
Look at the post, explains the Starting Fluid Test.
#3 cyl is the port that runs the fuel pump. Inspect that.
WinnerCougar74
Both float bowls were full so seems like fuel is correct. Pump diaphragm was ok. It seems like the question is, what causes a difference on one cylinder by 50psi. Since the piston, bearings and crank seem tight what could it be, broken ring? cracked piston? or blown head gasket?
WinnerCougar74
Also, there seems to be conflicting opinions on the fuel pump causing low compression on the #3 cylinder. Does anyone know for sure?
WinnerCougar74
plugs pulled yesterday, from right to left 1-4, #1&2 insulator tip white, #3&4 insulator tip dark, what would cause the bottom two cylinders to run rich, would it have something to do with the fuel pump attached to the #3 intake cover?
Remove bypass cover for #3 and post pictures of piston rings / skirt.
jerryjerry05
If the pump was OK?? do what Racerone suggested.
Remove the cover and push on the rings and see if they are loose or stuck.
WinnerCougar74
The autopsy has begun. Here are some images of cylinder #3.
WinnerCougar74
All are cylinder #3 on the exhaust side
#0021 right side of the picture is the piston wall, left side is head.
#0038 is the same area from a different angle.
#0040 is the same area
#0042 is another gouge
here is another picture showing both gouges #0035
So this doesn't look that bad?
WinnerCougar74
Another picture showing some of the top of the piston and the 2 gouges
Simple.-----Motor has to come apart.-----Something let go inside the motor !
WinnerCougar74
Thank You, racerone, for your opinion. The pitted pistons have been like that since I got it, now #3 is a little worse, prolly a chunk broke off. It's not grenaded but definitely would have to be resleeved, new pistons, rings and a new head and on and on.
WinnerCougar74
I learned so much from you. Thx! Prolly moving on to a looper evinrude with an oil pump. I do a lot of trolling and would really like to only have one motor hanging off the back. Boat is a very nice 1974 Winner Cougar 19 ft fiberglass (pic in my profile). When the chrysler was running well it would push it to 38 mph. I'm thinking about a 1990's or 2000's Evinrude 70 hp with a trolling flap and selling the 9.9 trolling motor. The factory catalog for the Winner says the 70 hp will push the boat to 30 mph. I rarely go 30. I troll a lot and search for fish and bait a lot so tons of hours at low speeds. Top speed is not that big of a deal. What would you think of downsizing. The total number of people in the boat is 4 plus fishing gear.
WinnerCougar74
Can a Evinrude crossflow idle all day without fouling plugs. I'm not going through that again.
They will idle all day long and the next day !!-----This concept of plugs fouling is not well understood in my opinion.-----I trolled with a 235 HP V-6 crossflow for hrs at a time.
