1974 Chrysler 105hp
CHRYSLER105
I Just Bought A 1974 Chrysler Outboard 105hp And Replaced A Missing Spark Plug Boot. I Haven't Been Able To Start It. It Trys To Start And Spins. The Closest I Can Get To Cranking It Is By Tossing Some Gas Into The Two Carbs On The Front Of The Motor.
If Anyone Can Help, I Would Appreciate It A Lot.
Thanks
scotts435
Re: 1974 Chrysler 105hp
Does the starter pinion engage the flywheel ring gear or is the starter motor itself spinning and not dogging in? Do you have spark? Does squirting fuel in cause it to pop? If so, fuel system may be your problem. How long has it set without being run before you bought it?
