1974 85HP Johnson Shift rod disconnect.
James R
I am about to pull the lower unit for service. The shift rod disconnect is not apparent. My manual does not show this model lower unit. Can anyone tell me where the disconnect is.
Thanks.
Re: 1974 85HP Johnson Shift rod disconnect.
It is behind the lower carburetor.-----Need a 5/8" wrench to take out one bolt.----Seperate those 2 arms you find there.
dodgeman67
I disconnected the shift cables and had much more room.
boobie
Make sure you don't lose the little nylon bushing in the upper shift rod connector as they are NLA.
James R
Thanks for the warning boobie. At the moment it is stuck in the plate.
boobie
You're welcome. That is sometimes an over looked item.
