whereismymonkey
Thread starter- Joined
- Nov 2, 2014
- 7
Hi, I have a 74 or 74 30 hp Chrysler. Not sure exactly. Anyway its not pumping water at all. I pulled apart lower leg and after putting a drill on the drive shaft to check if the water was pumping, I noticed if I tried to block the water pump to simulate pressure then it would spray water out of the side of the water pump through a tiny hole. On closer inspection of the water pump housing there is a pin hole underneath which goes to the side. Is this suppose to be here as a pressure relief or something? It looks like its manufactured but doesn't make sense...In advance, yes the impellor is new and fine.
